Salta al contenuto principale
  1. Heat to soften back cover sticker. Place suction cup and pull open a gap.
    • Heat to soften back cover sticker.
    • Place suction cup and pull open a gap.
  2. Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover. Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover. Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover.
    • Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover.
  3. Remove the battery. Remove the battery. Remove the battery.
    • Remove the battery.
  4. Twist off two screws here. Release all the connectors connecting with loudspeaker assembly. Remove vibrator securing bracket.
    • Twist off two screws here.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove vibrator securing bracket.
  5. Remove loudspeaker assembly cover and assembly itself. Remove loudspeaker assembly cover and assembly itself.
    • Remove loudspeaker assembly cover and assembly itself.
  6. Pry up the MIC. It's a part of the main flex. Release the connector with LCD screen flex and the connector with motherboard. Release the connector with LCD screen flex and the connector with motherboard.
    • Pry up the MIC. It's a part of the main flex.
    • Release the connector with LCD screen flex and the connector with motherboard.
  7. Push the upper power button & volume button flex branch bracket as the direction marked, and then remove it easily. Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not. Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not.
    • Push the upper power button & volume button flex branch bracket as the direction marked, and then remove it easily.
    • Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not.
  8. Get the flex from the sticker underneath carefully. And then, take the power button & volume button flex branch out from the slot. Finally, remove the whole main flex.
    • Get the flex from the sticker underneath carefully.
    • And then, take the power button & volume button flex branch out from the slot.
    • Finally, remove the whole main flex.
Conclusione
Altre 11 persone hanno completato questa guida.
Sophia
Membro da: 25/03/2014
42.104 Reputazione
62 Guide realizzate
Hello
I changed my power, but I felt the power button action do you think the problem of what can be
Thanks
mehdi ghanbarian - Replica
very good thnx
gamaa19700 - Replica
Is it ok to remove the small copper stickers under the flex?
Miguel Damayo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 57
Tutti i Tempi: 7,598
