Salta al contenuto principale
Sony Xperia Z3 Dual Loudspeaker Assembly Replacement
Cosa ti serve
Panoramica Video
  1. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: passo 1, immagine 1 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: passo 1, immagine 2 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: passo 1, immagine 3 di 3
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 2, immagine 1 di 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 2, immagine 2 di 2
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 3, immagine 1 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 3, immagine 2 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 3, immagine 3 di 3
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 4, immagine 1 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 4, immagine 2 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 4, immagine 3 di 3
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 5, immagine 1 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 5, immagine 2 di 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 5, immagine 3 di 3
    • Pry up the assembly and carry it out.
  6. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 6, immagine 1 di 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: passo 6, immagine 2 di 2
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
Conclusione
Altre 4 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.810 Reputazione
62 Guide realizzate
2 Commenti
this is all good but is there a link to the part ?
morten hundevad - Replica
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,396
