Salta al contenuto principale
Sony Xperia Z3 Dual Front Camera Replacement
Cosa ti serve
  1. Sony Xperia Z3 Dual Front Camera Replacement, Front Camera: passo 1, immagine 1 di 1
    • Power off the phone and remove two SIM card trays before replacement.
  2. Sony Xperia Z3 Dual Front Camera Replacement: passo 2, immagine 1 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 2, immagine 2 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 2, immagine 3 di 3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Front Camera Replacement: passo 3, immagine 1 di 1
    • Remove back cover carefully and avoid cracking the glass.
  4. Sony Xperia Z3 Dual Front Camera Replacement: passo 4, immagine 1 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 4, immagine 2 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 4, immagine 3 di 3
    • Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
  5. Sony Xperia Z3 Dual Front Camera Replacement: passo 5, immagine 1 di 1
    • Remove screws at first.
  6. Sony Xperia Z3 Dual Front Camera Replacement: passo 6, immagine 1 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 6, immagine 2 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 6, immagine 3 di 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Front Camera Replacement: passo 7, immagine 1 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 7, immagine 2 di 3 Sony Xperia Z3 Dual Front Camera Replacement: passo 7, immagine 3 di 3
    • Release all the connectors connecting with motherboard.
    • Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
  8. Sony Xperia Z3 Dual Front Camera Replacement: passo 8, immagine 1 di 2 Sony Xperia Z3 Dual Front Camera Replacement: passo 8, immagine 2 di 2
    • Release the connector and pull out the flex at first, please be careful as you can.
    • Remove the front camera finally.
Conclusione
Altre 2 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.810 Reputazione
62 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,333
