Salta al contenuto principale
Sony Xperia Z3 Dual Earpiece Speaker Replacement
Cosa ti serve
  1. Sony Xperia Z3 Dual Earpiece Speaker Replacement, Earpiece Speaker: passo 1, immagine 1 di 1
    • Power off and remove two SIM card trays at first before earpiece speaker replacement.
  2. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 2, immagine 1 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 2, immagine 2 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 2, immagine 3 di 3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 3, immagine 1 di 1
    • Remove back cover.
  4. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 4, immagine 1 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 4, immagine 2 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 4, immagine 3 di 3
    • It's easy to remove the battery.
  5. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 5, immagine 1 di 1
    • Twist off two screws at first.
  6. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 6, immagine 1 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 6, immagine 2 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 6, immagine 3 di 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 7, immagine 1 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 7, immagine 2 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 7, immagine 3 di 3
    • Release all the connectors connecting with motherboard.
    • Pry motherboard up from left side. It's really hold tightly by some hidden keys, so be careful.
    • Remove motherboard.
  8. Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 8, immagine 1 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 8, immagine 2 di 3 Sony Xperia Z3 Dual Earpiece Speaker Replacement: passo 8, immagine 3 di 3
    • Remove the blocker beside earpiece speaker and you can see the breakout to pry up the speaker.
    • Remove earpiece speaker finally.
Conclusione
Altre 13 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.810 Reputazione
62 Guide realizzate
3 Commenti
Thanks for the guide, it worked very well.
Maybe it's worth mentioning that there's a sticker at the back of the battery and you shouldn't be afraid to just pull the battery out.
Steven Kolenberg - Replica
Hai. Can you give me the link to buy the earpiece? Tq
Wafi Sams - Replica
Thanks for the guide, however my ear piece speaker now rattles when i play music at medium levels. I have tried installing additional adhesive to it, but still cracks.
Tony Ho - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 16,196
