Salta al contenuto principale
Sony Xperia Z3 Dual Battery Replacement
Cosa ti serve
Panoramica Video
  1. Sony Xperia Z3 Dual Battery Replacement, Battery: passo 1, immagine 1 di 2 Sony Xperia Z3 Dual Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Heat the back cover to soften the adhesive sticker.
    • Use the suction cup to open a gap from top side or bottom side.
  2. Sony Xperia Z3 Dual Battery Replacement: passo 2, immagine 1 di 3 Sony Xperia Z3 Dual Battery Replacement: passo 2, immagine 2 di 3 Sony Xperia Z3 Dual Battery Replacement: passo 2, immagine 3 di 3
    • Insert into the guitar pick and slide to cut the sticker.
    • Remove the back cover.
  3. Sony Xperia Z3 Dual Battery Replacement: passo 3, immagine 1 di 1
    • Release battery flex connector carefully to avoid breaking the pins.
  4. Sony Xperia Z3 Dual Battery Replacement: passo 4, immagine 1 di 1
    • Get free that sticker which for fastening the battery.
  5. Sony Xperia Z3 Dual Battery Replacement: passo 5, immagine 1 di 1
    • Pry up with a little effort because there is adhesive under the battery though not so strong.
  6. Sony Xperia Z3 Dual Battery Replacement: passo 6, immagine 1 di 1
    • That's Sony Xperia Z3 Dual 3100mAh battery.
    • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
Conclusione
Altre 12 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.810 Reputazione
62 Guide realizzate
2 Commenti
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - Replica
Just finished this guide thank you!
Seb Carroll - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 28,190
