Salta al contenuto principale
Sony Xperia Z2 Rear / Battery Cover Replacement
Cosa ti serve
Panoramica Video
  1. Sony Xperia Z2 Rear / Battery Cover Replacement, Rear / Battery Cover: passo 1, immagine 1 di 3 Sony Xperia Z2 Rear / Battery Cover Replacement, Rear / Battery Cover: passo 1, immagine 2 di 3 Sony Xperia Z2 Rear / Battery Cover Replacement, Rear / Battery Cover: passo 1, immagine 3 di 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Rear / Battery Cover Replacement: passo 2, immagine 1 di 3 Sony Xperia Z2 Rear / Battery Cover Replacement: passo 2, immagine 2 di 3 Sony Xperia Z2 Rear / Battery Cover Replacement: passo 2, immagine 3 di 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Rear / Battery Cover Replacement: passo 3, immagine 1 di 2 Sony Xperia Z2 Rear / Battery Cover Replacement: passo 3, immagine 2 di 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
Conclusione
Altre 22 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.464 Guide realizzate
8 Commenti
Hello
Does anyone else have problems when replaced new back panel - its coming off by himself.. the 3M double side tape doesn't hold it in place..
I glued it on already 3 times.. placed tape in every empty space :) and after few weeks, top right corner is open again.
(Same for my wife's Z3 Compact)
Maybe someone have some sugestions?
Thanks
jakadels - Replica
have the same issues now looking for a permanent glue for front and back plus a rigid aluminum bumper cover and maybe replacing the plastic back cover by a cooper one for better cooling
coolman234 -
When we fix the back cover at our shop we always spread just a little Loctite in every corner, sides and top + bottom. Make sure the battery doesn't have bumps sticking up from the back cover removal, try to "massage" them in so it gets flat again. The original back also has white sticky tape over the battery, if you can't get the exact tape don't bother putting other adhesive except fluid glue which doesn't harm the battery on it. Remove all the white sticky tape unless perfectly flat. Even the slightest push from below the back cover will loosen the corners eventually with only tape.
Svenpa - Replica
There is a nfc antenna glued to the back panel and this guide doesn't even mention it. At least my replacement back panel didn't come with an antenna on it and I noticed this *after* sticking it to the phone so I had to reopen the back and somehow shattered my new panel. Thanks guide.
Xingchen Hong - Replica
I recently replaced the back cover, for my z2, but now my camera has this smokey effect when i use the flash.
Anyone know how i can fix this.
TIA
Kendi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 23
Tutti i Tempi: 42,906
