Salta al contenuto principale
Sony Xperia Z2 Main Camera Replacement
Cosa ti serve
Panoramica Video
  1. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: passo 1, immagine 1 di 3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: passo 1, immagine 2 di 3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: passo 1, immagine 3 di 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Main Camera Replacement: passo 2, immagine 1 di 3 Sony Xperia Z2 Main Camera Replacement: passo 2, immagine 2 di 3 Sony Xperia Z2 Main Camera Replacement: passo 2, immagine 3 di 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Main Camera Replacement: passo 3, immagine 1 di 2 Sony Xperia Z2 Main Camera Replacement: passo 3, immagine 2 di 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    Should include the information about the NFC antenna.
    Sounds like a dealbreaker for some people.
    Diogo Pinheiro - Replica
    What about it?
    Makos - Replica
  4. Sony Xperia Z2 Main Camera Replacement, Main Camera: passo 4, immagine 1 di 2 Sony Xperia Z2 Main Camera Replacement, Main Camera: passo 4, immagine 2 di 2
Conclusione
Altre 9 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
7 Commenti
Where can I buy Spear main camera bucz my main camera is not functioning. Please help please... Please link me a website where I can buy it online.
Kushal maharjan - Replica
search ebay for "sony xperia z2 camera", unbelievable right?
deftoner -
I crashed my sony z2 and after i fix the screen i but the camera and it's overheated and doesn't work.what i must do and change
chris kat - Replica
I replied the comment to the other guy
deftoner -
My Camara get overheated too, and does not work, trying to replace it, where can I get it replace and how much does it go for thanks
Tripleboss - Replica
the camera have like a coil for do the focus, may be you short circuit it during the replace. There is 10 and 15 US replace camera from china at ebay. Try at fixez dot com
deftoner -
Hi, I replaced back camera in my Sony Xperia Z3c but it still doesn't work. It shows black screen. Do you think it's something which can be solved?
lucia.quitadamo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 9,112
