Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
How to disassemble the phone and replace the Loudspeaker.
Please SUBSCRIBE to my channel ツ
Panoramica Video
  1. Switch off the phone. If you can't switch it off, you can use the OFF button near to the SIM card Tray. Warm the Back Cover. You can use a hairdryer.
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Use a small suction cup and plastic tools for separating the Rear panel. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape). Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Disconnect the Battery Flex Cable and remove the two Philips screws. Li-Polymer Battery, 3.8V, 3200mAh Part number: LIS1543ERPC
  5. Remove the Loudspeaker metal bracket. Remove the Loudspeaker metal bracket. Remove the Loudspeaker metal bracket.
    • Remove the Loudspeaker metal bracket.
  6. Part of the Volume/PowerON/Mic flex cable is affixed onto the Loudspeaker/Vibro motor module. Under the Flex cable is the Loudspeaker. You can change only the Loudspeaker or or the Loudspeaker & Holder module.
    • Part of the Volume/PowerON/Mic flex cable is affixed onto the Loudspeaker/Vibro motor module.
    • Under the Flex cable is the Loudspeaker.
    • You can change only the Loudspeaker or or the Loudspeaker & Holder module.
    • Loudspeaker & Holder module Part No: 1282-2013
    • Please SUBSCRIBE to my channel ツ
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
177.188 Reputazione
317 Guide realizzate
Master Techs Membro di Master Techs
Community
295 Membri
972 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 26
Tutti i Tempi: 8,909
