Introduzione
Sony Xperia Z2 (D6502, D6503, and D6543) - How to disassemble the phone and replace the Earpiece.
Cosa ti serve
Panoramica Video
Switch off the phone.
If you can't switch it off, you can use the OFF button near to the SIM card Tray.
Warm the Back Cover. You can use a hairdryer.
Disconnect the Battery Flex Cable and remove the two Philips screws.
Li-Polymer Battery, 3.8V, 3200mAh
Part number: LIS1543ERPC
Disconnect one by one:
Magnetic Charging Dock Flex Cable
Volume / Power Button and Microphone Flex Cable
Main Camera
Audio Jack and Light Sensor Flex cable
Coaxial Antenna Cable
Altre 7 persone hanno completato questa guida.
3 Commenti
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
