Introduzione
This guide will show you how you replace the headphone jack.
Strumenti
Ricambi
Nessuna parte specificata.
Heat along the edges of the back cover using a heat gun to soften the glue.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
Remove the square rubber gasket from the camera using the plastic spudger.
To remove the headphone jack, cut the sticker between the headphone jack and the midframe with sharp tweasers.
Quasi finito!
Conclusione
