Introduzione
Also known as Xperia Z LT36i, Xperia C6603, Xperia C6602, Xperia Z LTE, Xperia Z HSPA+
How to change broken, not working Digitizer or Display.
This procedure is very hard. You must have experience to do this.
Cosa ti serve
Panoramica Video
Warm the Battery cover before disassemble it.
Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
Thats not the cable for the homebuttons its for the LCD screen
You are right. I will correct it.
ZFix -
All's well, that ends well. :)
Did you do it successfully?
Altre 76 persone hanno completato questa guida.
54 Commenti
with a hairdryer for like 3 min on high
The procedure is similar. You must use hot air to separate the Touch scree & LCD display from the frame. Of course, the disassembling have a difference.
Need to know where to get parts so I can try it out. My screen had one big Crack, I got !@#$%^ and cracked it more
Todd K
hi, I Have Xperia Z Last Month it Was Brokan On My Hand..In Case Is Touch Glass Broke
I Was Contact With service Center..he was Told me to change it complte screen
but Problem is it only touch Pad broke , so how do change complte
help me
I just try to change the digitalizer only but it's really hard to remove it without braking the LCD.
I'll recommend to change the glass and the LCD. You will receive assemble AND with new adhesives.
same problem,did u got solution for this
praveen -
Earlier this month i woke up and my screen was really dark android os was running but only visible under bright light. Then the brightness started flickering, then went dark again. All my notifications work when people call my phone rings i just cant see. Can replacing the screen fix this problem? Ive heard people say fix the backlight but i have yet to find the replacement part. Please i really need help!!!
Everythink looks great but something is missing
How will I install the back cover?
It is a water proof device after all.
plz answer where do i get xperia z display
There are many choices on ebay. I'm not sure which one you need
Try ebay ashwani
I replaced the screen with no issues but now the microphone doesn't work. I ordered a new flex to replace it, installed it, and still no mic. Any ideas?
My microphone doesn't work after replacing the display. I ordered and installed a new flex but still no mic. Any ideas?
help when i used my black 3m tape adhesive the front glass pushed off from the bottom what do i use to make the screen stay in
Is the procedure for replacement of only the digitizer the same as for both digitzer and lcd?
And to seperate digitizer from lcd is heating needed or...?
I have done the following, but i have diassembled the touch screen keeping the lcd. Now I assembled again, but the screen remains white when i switch one. I don't know what I can have done wrong. Any help?
Thanks!
Maybe until disassembling you damaged your LCD display. The only way to find the problem is to try with another working spare part.
ZFix -
How to fix back cover after screen replacement??
Will my xperia z still waterproof?
To be water proof again, you must use adhesive sticker especially for the model, like this for Xperia Z2, Step 13:
Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement
ZFix -
I can talk French?!
Hi,
I managed to replace my broken screen thanks to this guide. Thank you for that!
Unfortunately I´m facing now new problem after mounting phone back together - I can´t get any sound out from the ear speaker and loud speaker. Does anyone have any idea what could gone wrong? I´ve already checked cable connections to the motherboard, but no luck.
Hello,
I successfully replaced lcd, but now wlan signal is very low and dropping. If I connect or disconnect antenna cable, the reception signal is the same, so maybe I damaged green pcb under vibrate motor? Is there anything else that I should check?
can I replace my c6602 mainbaord with c6603?
hi i have sonny xperia z1s and screen cracked i ordered a screen with frame so it would be easier to change it but i got z1 screen and frame would z1 screen and frame fit to my z1s?
Hi, is it possible to replcae an xperia Z black frame with a white one ? or the replacement part must have the same color to fit ?
I have a cracked screen only, I ordered a new one off eBay but came with a frame. Now do I have to change all my motherboard, cameras, basically everything into new frame and screen or can I simply take the screen out of new frame purchased and replace the cracked one currently on my phone? Thanks
the battery, there is a nail to pull out
Price of display pdf screen
Pls how can I get Sony Xperia z screen online? I really need for the replacement of the broken one that I have..my email is olusanyaf@yahoo.com
Where buy original LCD?
Hi
I want to get a new display because my phone's display is not working properly. Left and right sides are not working from last few days. How will I get it?
hxiiiin@gmail.com
Hi, similar problem here. It might benefit others to know that some phones are very fussy about the EM permeability of the touch screen; the reason for low signal could be that simple. I am working on a Z and using my idea would allow a screen replacement to be graded without ever opening the box so if substandard could be sent back unopened (most sellers refuse to refund if screen is used at all) the same method can also be verifiably used to evaluate non OEM batteries and compare to the original to see if they are genuine new, genuine used or counterfeit.
Merhaba ben anlamiyorum hic LT36i ile C6602 ekranlari aynimi ayni cerceve falanmi kullaniliyor iksindede?
superbe vraiment tres tres interessant merci
j'ai suivi ta réparation sur l'asus mémo pad 172v j'ai réussi a flashé mais il reste un problème elle est trop lourde je ne sais pas si c'est un virus ou autre
I recently changed the lcd for my Xperia Z, at first it worked fine but after 4 days it just stopped it doesn't sense anything when i touch. Anyone who knows how to solve this problem?
Hello dosto mujy sony experia ZR ka docomo unit ki zarorat hy agar kisi ke pas hy to plz mujy is number pe call kijiyi 03475774372
Very difficult? 40-50mins? ..not really
I did it without heating any part in almost half an hour.
Btw you should do something with images quality, anyway thanks for sharing dude!
