Salta al contenuto principale
Introduzione
Also known as Xperia Z LT36i, Xperia C6603, Xperia C6602, Xperia Z LTE, Xperia Z HSPA+
How to change broken, not working Digitizer or Display.
This procedure is very hard. You must have experience to do this.
Please SUBSCRIBE to my channel ツ
Panoramica Video
  1. Warm the Battery cover before disassemble it. Warm the Battery cover before disassemble it. Warm the Battery cover before disassemble it.
    • Warm the Battery cover before disassemble it.
  2. 'Carefully' warm the battery too 'Carefully' warm the battery too 'Carefully' warm the battery too
    • 'Carefully' warm the battery too
  3. Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board. Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board. Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board.
    • Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board.
  4. This are: main Camera, front Camera and antenna wire Flex cable. Now we can remove the Motherboard. Now we can remove the Motherboard.
    • This are: main Camera, front Camera and antenna wire Flex cable.
    • Now we can remove the Motherboard.
  5. The Headphone connector and the Ringer / Cover / Signal Antenna module. The Headphone connector and the Ringer / Cover / Signal Antenna module. The Headphone connector and the Ringer / Cover / Signal Antenna module.
    • The Headphone connector and the Ringer / Cover / Signal Antenna module.
  6. Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go. Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go. Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
    • Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
  7. Warm the Touch screen before you start to disassemble it. Warm the Touch screen before you start to disassemble it. Warm the Touch screen before you start to disassemble it.
    • Warm the Touch screen before you start to disassemble it.
  8. Let's assemble the new spare part. Let's assemble the new spare part. Let's assemble the new spare part.
    • Let's assemble the new spare part.
  9. All's well, that ends well. :) . Did you do it successfully?
Conclusione
Altre 76 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
166.755 Reputazione
305 Guide realizzate
Master Techs Membro di Master Techs
Community
288 Membri
820 Guide realizzate
Same procedure with Sony Xperia Z2?
Fredrik - Replica
How do you warm it? With what and what temperature ?
Jeroen - Replica
with a hairdryer for like 3 min on high
Peter Tembo -
With hair dryer.
ZFix - Replica
Same procedure with Sony Xperia Z1? Where do i get the screen parts?
chrgro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 181
Tutti i Tempi: 229,835
