Salta al contenuto principale
Sony Xperia XZ2 LCD Screen Replacement
Cosa ti serve
  1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 LCD Screen Replacement: passo 2, immagine 1 di 3 Sony Xperia XZ2 LCD Screen Replacement: passo 2, immagine 2 di 3 Sony Xperia XZ2 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 LCD Screen Replacement: passo 3, immagine 1 di 2 Sony Xperia XZ2 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 LCD Screen Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Gently remove the connector by using a spudger to pop it off.
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team S19-G5, White Winter 2019 Membro di Cal Poly, Team S19-G5, White Winter 2019
CPSU-WHITE-W19S19G5
4 Membri
12 Guide realizzate
4Commenti sulla guida
Worked perfectly fine for my xz2 compact
Maria Schrenk - Replica
Hi, someone knows how to glue it back. I read that if I use B-6000 glue it will damage my screen.
Diego Covenas - Replica
Double-sided adhesive should do the trick. For example 2mm Universal 3M Adhesive Tape should be preferred to glue.
Célestin Taramarcaz -
The XZ2 Compact has the same screen connector+clip.
My screen came without the upper speaker grille (plastic+fabric). When I tried to remove the glue from the old one the fabric got delaminated from the plastic. Tip: Check if the grille is in place before gluing back!
Dimitrios Josef Moustos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 87
Tutti i Tempi: 10,976
