Salta al contenuto principale
Sony Xperia XZ1 Compact Battery Replacement
Cosa ti serve
Istruzioni Video
Conclusione
Altre 6 persone hanno completato questa guida.
Witrigs
Membro da: 11/24/15
69.451 Reputazione
378 Guide realizzate
3 Commenti
This is a very good instruction for a job that has lots of work to do. Kudos for the author.
It took me about 2 hours to get my phone ready to use.
The hardest part was to remove the battery from the motherboard without braking anything.
Harri Vähätalo - Replica
Réalisé en +/- 2h. Bien expliqué, merci !
Patrick JOACHIM - Replica
Useful tip from @kire456 on youtube: "A tip for others: the glue strip along the edges of the screen is only 1.5mm wide, and behind the LCD screen is a very fragile reflective sheet of foil that is easily damaged. So make sure not to wedge your plastic card in deeper than you need to, when you are removing the LCD screen. I did, and damaged the reflective foil."
tony - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 126
Tutti i Tempi: 10,542
