Introduzione
You will learn how to remove the motherboard from the Sony Xperia XZ Premium. This process includes unscrewing nine screws and removing the frame pieces. It is important to keep your work-space organized because there will be several pieces of the phone removed.
Cosa ti serve
Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
Place the spudger under the top right frame piece and lift to loosen it.
上部右側フレームの下には、バイブレータがあります。バイブレータとマザーボードをつなぐコネクタはなぜか上部右上フレームに接着されています(接着されていなくてもよい気がします)。
上部右側フレームを持ち上げる際には、そっとコネクタを外した方が安全です。
https://youtu.be/JmN7pZdgJDU?t=133
バイブレーターのカバーは、シリコン製です。外れやすいので見失わないようにしてください。
Insert your nail under the top left connector and push to disconnect it.
Insert spudger in the gap above the battery and lift to loosen the motherboard.
Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
フロントカメラの取り外し手順が省かれており、最低限カメラのシールドを止めているネジを取り外す必要があります。
また、SIMカード、SDカードも前もって外しておかないと、マザーボードが浮いてきません。 -
Altre 5 persone hanno completato questa guida.
4 Commenti
Where do you buy a motherboard for the xz premium? thank you
If you know the name of the motherboard you can check on:
newegg.com
aliexpress.com
https://www.sony.com/electronics/support...
amazon.com
alibaba.com
Is it okay to use a hair dryer instead of iOpener?
091 03718 - Replica
