Introduzione
You will learn how to remove the motherboard from the Sony Xperia XZ Premium. This process includes unscrewing nine screws and removing the frame pieces. It is important to keep your work-space organized because there will be several pieces of the phone removed.
Parti
Nessuna parte specificata.
Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
Insert your nail under the top left connector and push to disconnect it.
Altre 5 persone hanno completato questa guida.
4 Commenti
Where do you buy a motherboard for the xz premium? thank you
If you know the name of the motherboard you can check on:
newegg.com
aliexpress.com
https://www.sony.com/electronics/support...
amazon.com
alibaba.com
