Salta al contenuto principale
Sony Xperia XZ Premium Front Camera Replacement
Cosa ti serve
  1. Sony Xperia XZ Premium Front Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
    Is it okay to use a hair dryer instead of iOpener?
    091 03718 - Replica
  2. Sony Xperia XZ Premium Front Camera Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Front Camera Replacement: passo 3, immagine 1 di 1
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Front Camera Replacement, Front Camera: passo 4, immagine 1 di 1
    • Remove the two bottom left 3.9 mm Phillips #000 screws.
  5. Sony Xperia XZ Premium Front Camera Replacement: passo 5, immagine 1 di 1
    • Insert the spudger under the bottom left frame and lift, try to lift vertically to wedge it out.
  6. Sony Xperia XZ Premium Front Camera Replacement: passo 6, immagine 1 di 1
    • Grab hold of the bottom left frame and lift out carefully.
  7. Sony Xperia XZ Premium Front Camera Replacement: passo 7, immagine 1 di 1
    • Insert a spudger under the tab above the camera and lift to disconnect it.
  8. Sony Xperia XZ Premium Front Camera Replacement: passo 8, immagine 1 di 1
    • Grab hold of the tab with your fingers.
  9. Sony Xperia XZ Premium Front Camera Replacement: passo 9, immagine 1 di 1
    • Lift the camera from the phone by the tab.
Conclusione
Gelene Amog
Membro da: 04/18/18
1.165 Reputazione
5 Guide realizzate
Cal Poly, Team S18-G2, Livingston Spring 2018 Membro di Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 Membri
16 Guide realizzate
Un commento
The name of this tutorial is incorrect.
Gavin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,153
