Salta al contenuto principale
Sony Xperia XA2 Ultra Charging Port Replacement
Cosa ti serve
  1. Sony Xperia XA2 Ultra Charging Port Replacement, Rear Cover: passo 1, immagine 1 di 2 Sony Xperia XA2 Ultra Charging Port Replacement, Rear Cover: passo 1, immagine 2 di 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Charging Port Replacement: passo 2, immagine 1 di 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Charging Port Replacement: passo 3, immagine 1 di 2 Sony Xperia XA2 Ultra Charging Port Replacement: passo 3, immagine 2 di 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Charging Port Replacement: passo 4, immagine 1 di 2 Sony Xperia XA2 Ultra Charging Port Replacement: passo 4, immagine 2 di 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Charging Port Replacement: passo 5, immagine 1 di 2 Sony Xperia XA2 Ultra Charging Port Replacement: passo 5, immagine 2 di 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Charging Port Replacement: passo 6, immagine 1 di 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Charging Port Replacement, Speaker: passo 7, immagine 1 di 2 Sony Xperia XA2 Ultra Charging Port Replacement, Speaker: passo 7, immagine 2 di 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  8. Sony Xperia XA2 Ultra Charging Port Replacement: passo 8, immagine 1 di 2 Sony Xperia XA2 Ultra Charging Port Replacement: passo 8, immagine 2 di 2
    • Using an iFixit opening tool, pry and remove the speaker.
  9. Sony Xperia XA2 Ultra Charging Port Replacement, Charging Port: passo 9, immagine 1 di 1
    • Using the iFixit opening tool, disconnect the flex cable.
  10. Sony Xperia XA2 Ultra Charging Port Replacement: passo 10, immagine 1 di 2 Sony Xperia XA2 Ultra Charging Port Replacement: passo 10, immagine 2 di 2
    • Remove both the black and white antenna cables using the Jimmy.
  11. Sony Xperia XA2 Ultra Charging Port Replacement: passo 11, immagine 1 di 1
    • Remove the vibration flex cable with the Jimmy.
  12. Sony Xperia XA2 Ultra Charging Port Replacement: passo 12, immagine 1 di 1
    • Using the Jimmy and the iFixit opening tool, remove the charging port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 176
