Salta al contenuto principale
Sony Xperia XA1 Ultra Back Camera Replacement
Cosa ti serve
  1. Sony Xperia XA1 Ultra Back Camera Replacement, Back Assembly: passo 1, immagine 1 di 2 Sony Xperia XA1 Ultra Back Camera Replacement, Back Assembly: passo 1, immagine 2 di 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Back Camera Replacement: passo 2, immagine 1 di 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Back Camera Replacement: passo 3, immagine 1 di 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Back Camera Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Back Camera Replacement: passo 5, immagine 1 di 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Back Camera Replacement: passo 6, immagine 1 di 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Back Camera Replacement, Antenna Module: passo 7, immagine 1 di 2 Sony Xperia XA1 Ultra Back Camera Replacement, Antenna Module: passo 7, immagine 2 di 2
    • Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
  8. Sony Xperia XA1 Ultra Back Camera Replacement: passo 8, immagine 1 di 2 Sony Xperia XA1 Ultra Back Camera Replacement: passo 8, immagine 2 di 2
    • Insert your iFixit Opening Tool underneath the antenna module.
    • Lift up gently with the iFixit Opening Tool to remove the antenna module.
    • The antenna module may be difficult to remove.
  9. Sony Xperia XA1 Ultra Back Camera Replacement, Back Camera: passo 9, immagine 1 di 2 Sony Xperia XA1 Ultra Back Camera Replacement, Back Camera: passo 9, immagine 2 di 2
    • Insert your iFixit Opening Tool between the back camera and the motherboard and gently lift up.
    • Lift up with the iFixit Opening Tool until the back camera is removed from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Jacob Jung
Membro da: 04/18/18
1.429 Reputazione
9 Guide realizzate
Cal Poly, Team S16-G3, Livingston Spring 2018 Membro di Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 655
