Salta al contenuto principale
Sony Xperia XA Loudspeaker Replacement
Cosa ti serve
  1. Sony Xperia XA Loudspeaker Replacement, Back Cover: passo 1, immagine 1 di 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Loudspeaker Replacement: passo 2, immagine 1 di 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Loudspeaker Replacement: passo 3, immagine 1 di 3 Sony Xperia XA Loudspeaker Replacement: passo 3, immagine 2 di 3 Sony Xperia XA Loudspeaker Replacement: passo 3, immagine 3 di 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Loudspeaker Replacement: passo 4, immagine 1 di 3 Sony Xperia XA Loudspeaker Replacement: passo 4, immagine 2 di 3 Sony Xperia XA Loudspeaker Replacement: passo 4, immagine 3 di 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Loudspeaker Replacement: passo 5, immagine 1 di 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Loudspeaker Replacement: passo 6, immagine 1 di 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Loudspeaker Replacement, Loudspeaker: passo 7, immagine 1 di 2 Sony Xperia XA Loudspeaker Replacement, Loudspeaker: passo 7, immagine 2 di 2
    • Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
  8. Sony Xperia XA Loudspeaker Replacement: passo 8, immagine 1 di 2 Sony Xperia XA Loudspeaker Replacement: passo 8, immagine 2 di 2
    • Push back the two retaining tabs on the top of the loudspeaker with the spudger.
  9. Sony Xperia XA Loudspeaker Replacement: passo 9, immagine 1 di 1
    • Pry the loudspeaker up with the spudger.
  10. Sony Xperia XA Loudspeaker Replacement: passo 10, immagine 1 di 1
    • Remove the loudspeaker with your hands.
Conclusione
Altre 2 persone hanno completato questa guida.
Stephen Rock
Membro da: 04/18/18
230 Reputazione
2 Guide realizzate
Cal Poly, Team S17-G2, Livingston Spring 2018 Membro di Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 490
