Salta al contenuto principale
Sony Xperia XA LCD Screen Replacement
Cosa ti serve
  1. Sony Xperia XA LCD Screen Replacement, Back Cover: passo 1, immagine 1 di 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA LCD Screen Replacement: passo 2, immagine 1 di 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA LCD Screen Replacement: passo 3, immagine 1 di 3 Sony Xperia XA LCD Screen Replacement: passo 3, immagine 2 di 3 Sony Xperia XA LCD Screen Replacement: passo 3, immagine 3 di 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA LCD Screen Replacement: passo 4, immagine 1 di 3 Sony Xperia XA LCD Screen Replacement: passo 4, immagine 2 di 3 Sony Xperia XA LCD Screen Replacement: passo 4, immagine 3 di 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA LCD Screen Replacement: passo 5, immagine 1 di 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA LCD Screen Replacement: passo 6, immagine 1 di 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA LCD Screen Replacement, Battery: passo 7, immagine 1 di 3 Sony Xperia XA LCD Screen Replacement, Battery: passo 7, immagine 2 di 3 Sony Xperia XA LCD Screen Replacement, Battery: passo 7, immagine 3 di 3
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA LCD Screen Replacement: passo 8, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA LCD Screen Replacement: passo 9, immagine 1 di 1
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA LCD Screen Replacement: passo 10, immagine 1 di 1
    • Lift the battery out with your hands.
  11. Sony Xperia XA LCD Screen Replacement, LCD Screen: passo 11, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement, LCD Screen: passo 11, immagine 2 di 2
    • Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
  12. Sony Xperia XA LCD Screen Replacement: passo 12, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 12, immagine 2 di 2
    • Push back the two retaining tabs on the top of the loudspeaker with the spudger.
  13. Sony Xperia XA LCD Screen Replacement: passo 13, immagine 1 di 1
    • Pry the loudspeaker up with the spudger.
  14. Sony Xperia XA LCD Screen Replacement: passo 14, immagine 1 di 1
    • Remove the loudspeaker with your hands.
  15. Sony Xperia XA LCD Screen Replacement: passo 15, immagine 1 di 1
    • With a spudger, pry up the orange connector that is directly underneath where the loud speaker was just removed.
  16. Sony Xperia XA LCD Screen Replacement: passo 16, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 16, immagine 2 di 2
    • Pry up the small silver connector on the right side of the bottom of the phone with a spudger.
  17. Sony Xperia XA LCD Screen Replacement: passo 17, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 17, immagine 2 di 2
    • Pry up the charging port using a spudger.
  18. Sony Xperia XA LCD Screen Replacement: passo 18, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 18, immagine 2 di 2
    • Remove the five black 4mm screws with a Phillips #00 screwdriver.
  19. Sony Xperia XA LCD Screen Replacement: passo 19, immagine 1 di 1
    • Pry up the black camera case with a nylon spudger, and then remove the case.
  20. Sony Xperia XA LCD Screen Replacement: passo 20, immagine 1 di 3 Sony Xperia XA LCD Screen Replacement: passo 20, immagine 2 di 3 Sony Xperia XA LCD Screen Replacement: passo 20, immagine 3 di 3
    • Use a spudger to pry up the six motherboard connectors.
  21. Sony Xperia XA LCD Screen Replacement: passo 21, immagine 1 di 1
    • Use the flat end of the nylon spudger to lift the camera out of the phone.
  22. Sony Xperia XA LCD Screen Replacement: passo 22, immagine 1 di 1
    • Pull out the front camera using your fingers.
  23. Sony Xperia XA LCD Screen Replacement: passo 23, immagine 1 di 1
    • Use the spudger to separate the motherboard from the frame.
  24. Sony Xperia XA LCD Screen Replacement: passo 24, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 24, immagine 2 di 2
    • Pry up the headphone jack using a spudger.
  25. Sony Xperia XA LCD Screen Replacement: passo 25, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 25, immagine 2 di 2
    • Peel back the black tabs that were holding the battery in place.
    • You may hear loud sounds as you pull the tabs because they are stuck with adhesive.
  26. Sony Xperia XA LCD Screen Replacement: passo 26, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 26, immagine 2 di 2
    • Remove the two 4 mm screws with a Phillips #000 screwdriver from the left side of the back of the screen.
  27. Sony Xperia XA LCD Screen Replacement: passo 27, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 27, immagine 2 di 2
    • Remove the three 3mm screws with a T5 screwdriver along the side of the device where the volume buttons are.
  28. Sony Xperia XA LCD Screen Replacement: passo 28, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 28, immagine 2 di 2
    • Push down the side of the screen that you just removed screws from.
  29. Sony Xperia XA LCD Screen Replacement: passo 29, immagine 1 di 3 Sony Xperia XA LCD Screen Replacement: passo 29, immagine 2 di 3 Sony Xperia XA LCD Screen Replacement: passo 29, immagine 3 di 3
    • Pull up the orange and black tab that is on the left half of the middle of the screen.
  30. Sony Xperia XA LCD Screen Replacement: passo 30, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 30, immagine 2 di 2
    • Remove the Wifi antenna.
  31. Sony Xperia XA LCD Screen Replacement: passo 31, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 31, immagine 2 di 2
    • Remove the three 3 mm screws with a Star Bit T5 Screwdriver on the opposite side of the phone.
  32. Sony Xperia XA LCD Screen Replacement: passo 32, immagine 1 di 2 Sony Xperia XA LCD Screen Replacement: passo 32, immagine 2 di 2
    • Use tweezers to remove the earpiece.
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team S17-G2, Livingston Spring 2018 Membro di Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 30
Tutti i Tempi: 4,180
