Salta al contenuto principale
Sony Xperia XA Battery Replacement
Cosa ti serve
  1. Sony Xperia XA Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Battery Replacement: passo 2, immagine 1 di 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Battery Replacement: passo 3, immagine 1 di 3 Sony Xperia XA Battery Replacement: passo 3, immagine 2 di 3 Sony Xperia XA Battery Replacement: passo 3, immagine 3 di 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Battery Replacement: passo 4, immagine 1 di 3 Sony Xperia XA Battery Replacement: passo 4, immagine 2 di 3 Sony Xperia XA Battery Replacement: passo 4, immagine 3 di 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Battery Replacement: passo 5, immagine 1 di 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Battery Replacement: passo 6, immagine 1 di 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Battery Replacement, Battery: passo 7, immagine 1 di 3 Sony Xperia XA Battery Replacement, Battery: passo 7, immagine 2 di 3 Sony Xperia XA Battery Replacement, Battery: passo 7, immagine 3 di 3
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA Battery Replacement: passo 8, immagine 1 di 2 Sony Xperia XA Battery Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA Battery Replacement: passo 9, immagine 1 di 1
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA Battery Replacement: passo 10, immagine 1 di 1
    • Lift the battery out with your hands.
Conclusione
Altre 11 persone hanno completato questa guida.
Cassidy Davis
Membro da: 04/18/18
621 Reputazione
1 Guida realizzata
Cal Poly, Team S17-G2, Livingston Spring 2018 Membro di Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Membri
8 Guide realizzate
Un commento
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Mike Jurkiewicz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 5,256
