Salta al contenuto principale
Sony Xperia U Headphone Jack Replacement
Cosa ti serve
  1. Sony Xperia U Headphone Jack Replacement, Battery: passo 1, immagine 1 di 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Headphone Jack Replacement, Headphone Jack: passo 3, immagine 1 di 1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Headphone Jack Replacement: passo 4, immagine 1 di 1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Headphone Jack Replacement: passo 6, immagine 1 di 1
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
Conclusione
Altre 2 persone hanno completato questa guida.
Bader
Membro da: 10/07/14
545 Reputazione
4 Guide realizzate
USF Tampa, Team 7-2, Leahy Fall 2014 Membro di USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,094
