Salta al contenuto principale
Sony Xperia U Battery Replacement
Cosa ti serve
  1. Sony Xperia U Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Battery Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
Faisal
Membro da: 10/07/14
204 Reputazione
1 Guida realizzata
USF Tampa, Team 7-2, Leahy Fall 2014 Membro di USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,358
