Salta al contenuto principale
Introduzione
We will show the user how to access and remove the phones loud speaker module.
Parti
Nessuna parte specificata.
  1. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Use the plastic opening tool to pry the bottom plastic section off. Use the plastic opening tool to pry the bottom plastic section off.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Batterie per PC portatili
    Batterie per tutti i migliori marchi di PC, supportate dalla nostra Garanzia di Qualità.
    Acquista ora
    Acquista ora
  4. Remove the four 5mm screws. Use the plastic opening tool to pry off the back. Use the plastic opening tool to pry off the back.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  5. Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module.
    • Use the plastic opening tool to remove the loud speaker module.
Conclusione
Adam Giniger
Membro da: 22/09/2014
1.247 Reputazione
8 Guide realizzate
USF Tampa, Team 4-4, Brown Fall 2014 Membro di USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 194
