Salta al contenuto principale
Sony Xperia TL Battery Harness Replacement
Cosa ti serve
  1. Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: passo 1, immagine 1 di 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: passo 1, immagine 2 di 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: passo 1, immagine 3 di 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: passo 2, immagine 1 di 2 Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: passo 2, immagine 2 di 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: passo 3, immagine 1 di 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: passo 3, immagine 2 di 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: passo 3, immagine 3 di 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Battery Harness Replacement, Loud Speaker: passo 4, immagine 1 di 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: passo 4, immagine 2 di 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: passo 4, immagine 3 di 3
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: passo 5, immagine 1 di 2 Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Battery Harness Replacement, Battery Harness: passo 6, immagine 1 di 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: passo 6, immagine 2 di 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: passo 6, immagine 3 di 3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Battery Harness Replacement: passo 7, immagine 1 di 1
    • The final step is taking the entire harness off of the phone.
Conclusione
Adam Giniger
Membro da: 09/22/14
1.303 Reputazione
8 Guide realizzate
USF Tampa, Team 4-4, Brown Fall 2014 Membro di USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 343
