Salta al contenuto principale
Sony Xperia T2 Ultra Dual Motherboard Replacement
Cosa ti serve
  1. Sony Xperia T2 Ultra Dual Motherboard Replacement, Rear Case: passo 1, immagine 1 di 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 2, immagine 1 di 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing the internal cover: passo 3, immagine 1 di 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 4, immagine 1 di 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 4, immagine 2 di 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing Chip: passo 5, immagine 1 di 1
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  6. Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 6, immagine 1 di 1
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  7. Sony Xperia T2 Ultra Dual Motherboard Replacement, Remove back facing camera: passo 7, immagine 1 di 1
    • Then using the tweezer, carefully remove the back facing camera component.
  8. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing the Front Camera: passo 8, immagine 1 di 1
    • Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
  9. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing chip: passo 9, immagine 1 di 1
    • Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
  10. Sony Xperia T2 Ultra Dual Motherboard Replacement, Remove audio jack: passo 10, immagine 1 di 1
    • Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
  11. Sony Xperia T2 Ultra Dual Motherboard Replacement, Motherboard: passo 11, immagine 1 di 2 Sony Xperia T2 Ultra Dual Motherboard Replacement, Motherboard: passo 11, immagine 2 di 2
    • Using tweezers, locate the battery connector and carefully pull up to disconnect it.
  12. Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 12, immagine 1 di 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 12, immagine 2 di 2
    • Carefully remove the button circuit connector by using tweezers and gently pulling up.
  13. Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 13, immagine 1 di 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 13, immagine 2 di 2
    • Carefully remove the silver plug by using the tweezers to lift straight up.
  14. Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 14, immagine 1 di 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 14, immagine 2 di 2
    • Carefully remove the SIM card connector using tweezers by gently pulling it straight up.
  15. Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 15, immagine 1 di 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: passo 15, immagine 2 di 2
    • Using tweezers, carefully remove the motherboard by pulling it up and out of the backing.
Conclusione
Altre 4 persone hanno completato questa guida.
IUPUI, Team S1-G3, Harley Spring 2017 Membro di IUPUI, Team S1-G3, Harley Spring 2017
IUPUI-HARLEY-S17S1G3
4 Membri
3 Guide realizzate
2 Commenti
Mayrka D5322 ke bad cahiy
Goving Ram Goving Ram - Replica
I have a sony xperia dual ultra T2
RAM 1GB ITS REALLY POOR FOR THE TAB
HOW CAN I CHANGE THE RAM.
ANS ME PLEASE
MP - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,609
