Salta al contenuto principale
Sony Xperia T2 Ultra Dual Front Facing Camera Replacement
Cosa ti serve
  1. Sony Xperia T2 Ultra Dual Front Facing Camera Replacement, Rear Case: passo 1, immagine 1 di 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Front Facing Camera Replacement: passo 2, immagine 1 di 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Front Facing Camera Replacement, Removing the internal cover: passo 3, immagine 1 di 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Front Facing Camera Replacement: passo 4, immagine 1 di 2 Sony Xperia T2 Ultra Dual Front Facing Camera Replacement: passo 4, immagine 2 di 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Front Facing Camera Replacement, Removing the Front Camera: passo 5, immagine 1 di 1
    • Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
Conclusione
Altre 8 persone hanno completato questa guida.
USF Tampa, Team 13-3, Staggers Fall 2014 Membro di USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 Membri
7 Guide realizzate
2 Commenti
From camera icon is not available
rameshmax - Replica
Front camera is not available
rameshmax - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,918
