Salta al contenuto principale
Sony Xperia Sola Speaker Replacement
Cosa ti serve
  1. Sony Xperia Sola Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Lay the phone as shown and put the camera facing up.
  2. Sony Xperia Sola Speaker Replacement: passo 2, immagine 1 di 2 Sony Xperia Sola Speaker Replacement: passo 2, immagine 2 di 2
    • Push the back cover as shown, then lift the cover off.
  3. Sony Xperia Sola Speaker Replacement: passo 3, immagine 1 di 3 Sony Xperia Sola Speaker Replacement: passo 3, immagine 2 di 3 Sony Xperia Sola Speaker Replacement: passo 3, immagine 3 di 3
    • Remove the five screws as shown on the phone by using 26 Bit Kit.
    • Use a T6 screwdriver bit to remove top two screws.
    • Use a J000 screwdriver bit to remove the bottom two screws.
    • Use a T3 screwdriver bit to remove the middle screw (close to camera).
  4. Sony Xperia Sola Speaker Replacement: passo 4, immagine 1 di 2 Sony Xperia Sola Speaker Replacement: passo 4, immagine 2 di 2
    • Use plastic opening tool to remove the bottom white cover as shown.
  5. Sony Xperia Sola Speaker Replacement: passo 5, immagine 1 di 2 Sony Xperia Sola Speaker Replacement: passo 5, immagine 2 di 2
    • There are two additional screws under the bottom white cover as shown.
    • Use T3 drivers to remove two additional screws as shown.
  6. Sony Xperia Sola Speaker Replacement: passo 6, immagine 1 di 3 Sony Xperia Sola Speaker Replacement: passo 6, immagine 2 di 3 Sony Xperia Sola Speaker Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using plastic opening tool, lift to remove the small black cover on the bottom left of phone as shown.
    • Then, using tweezers to lift the connector straight up to disconnect the battery's circuit as shown.
  7. Sony Xperia Sola Speaker Replacement: passo 7, immagine 1 di 3 Sony Xperia Sola Speaker Replacement: passo 7, immagine 2 di 3 Sony Xperia Sola Speaker Replacement: passo 7, immagine 3 di 3
    • Turn the phone onto its side and insert a flat object and gently remove cover, using plastic opening tool as shown.
  8. Sony Xperia Sola Speaker Replacement: passo 8, immagine 1 di 3 Sony Xperia Sola Speaker Replacement: passo 8, immagine 2 di 3 Sony Xperia Sola Speaker Replacement: passo 8, immagine 3 di 3
    • Flip over the black back cover and locate the speaker phone at the bottom, then use the tweezers to remove the speaker. It is glued to the back cover so a little force will be needed.
Conclusione
Altre 3 persone hanno completato questa guida.
Bo Wu
Membro da: 02/15/17
292 Reputazione
2 Guide realizzate
USF Tampa, Team S5-G3, Lacy Spring 2017 Membro di USF Tampa, Team S5-G3, Lacy Spring 2017
USFT-LACY-S17S5G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 346
