Salta al contenuto principale
Sony Xperia S Disassembly
Cosa ti serve
  1. Sony Xperia S Disassembly, Sony Xperia S Disassembly: passo 1, immagine 1 di 1
    • Remove the case (back cover)
  2. Sony Xperia S Disassembly: passo 2, immagine 1 di 1
    • Remove the screws in the indicated areas (Red Markings) with a screwdriver.
  3. Sony Xperia S Disassembly: passo 3, immagine 1 di 1
    • Then, detach the first bus (indicated with the red circle) to fully detach the case.
  4. Sony Xperia S Disassembly: passo 4, immagine 1 di 1
    • Then, you will see the battery, let's proceed to remove the battery.
  5. Sony Xperia S Disassembly: passo 5, immagine 1 di 1
    • To remove the battery, remove the two buses pointed out in red.
  6. Sony Xperia S Disassembly: passo 6, immagine 1 di 1
    • After removing the buses, we can remove the camera and the motherboard. Proceed to remove the motherboard.
  7. Sony Xperia S Disassembly: passo 7, immagine 1 di 1
    • Finally, after removing the motherboard, you have fully dismantled the phone.
Conclusione
To reassemble your device, follow the instructions in reverse order
Altre 3 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
es en
100%
Henry Ko ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
3 Commenti
hi..my xperia s totally crashed..it is not working at all..is there any way to get the data from the sd card..!!??please help..if i disassembled it ..can i run the sd card on another device or something like that or any thing ..please help..:(
soma ana - Replica
Hi Soma Ana,
Assuming that your SD card has not been corrupted or anything, you can plug it into your computer or another device (though I would personally recommend you to look from your computer) and find your old files.
Henry Ko -
estoy en la misma situaciĆ³n, pudiste encontrar la sd?
Leopold Fitz -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,073
