Salta al contenuto principale
Sony Xperia M4 Aqua Rear Camera Replacement
Cosa ti serve
  1. Sony Xperia M4 Aqua Rear Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Rear Camera Replacement: passo 2, immagine 1 di 1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Rear Camera Replacement: passo 3, immagine 1 di 2 Sony Xperia M4 Aqua Rear Camera Replacement: passo 3, immagine 2 di 2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Rear Camera Replacement: passo 4, immagine 1 di 1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Sony Xperia M4 Aqua Rear Camera Replacement, Battery: passo 5, immagine 1 di 1
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Sony Xperia M4 Aqua Rear Camera Replacement: passo 6, immagine 1 di 1
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Sony Xperia M4 Aqua Rear Camera Replacement: passo 7, immagine 1 di 1
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Sony Xperia M4 Aqua Rear Camera Replacement: passo 8, immagine 1 di 1
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
  9. Sony Xperia M4 Aqua Rear Camera Replacement, Rear Camera: passo 9, immagine 1 di 1
    • Remove the four hex head 3mm screws at each corner of the motherboard with a screwdriver.
  10. Sony Xperia M4 Aqua Rear Camera Replacement: passo 10, immagine 1 di 2 Sony Xperia M4 Aqua Rear Camera Replacement: passo 10, immagine 2 di 2
    • Remove three pieces of the securing bracket using tweezers
    This step is wrong. It’s actually two security brackets, not three, as long as you don’t break the one on the left/upper side. If you do it like it’s shown here you will break this part. The correct way to do this is remove the bracket on the right side, then remove the board with the other bracket still attached. Watch this video to get an idea: https://youtu.be/9o1DGKT76eo (interesting part starting at 1:50).
    Willkeinkonto - Replica
  11. Sony Xperia M4 Aqua Rear Camera Replacement: passo 11, immagine 1 di 2 Sony Xperia M4 Aqua Rear Camera Replacement: passo 11, immagine 2 di 2
    • Detach the rear camera connector from the front of the motherboard.
    • Remove the rear camera with your fingers or tweezers.
    Isn't front camerra?
    bambang purnomo - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 4-5, Lacy Spring 2016 Membro di USF Tampa, Team 4-5, Lacy Spring 2016
USFT-LACY-S16S4G5
3 Membri
8 Guide realizzate
2 Commenti
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - Replica
That's the front camera. You have the front and rear camera mixed up!
mivanchev - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,497
