Salta al contenuto principale
Sony Xperia M4 Aqua Battery Replacement
Cosa ti serve
  1. Sony Xperia M4 Aqua Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Battery Replacement: passo 2, immagine 1 di 1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Battery Replacement: passo 3, immagine 1 di 2 Sony Xperia M4 Aqua Battery Replacement: passo 3, immagine 2 di 2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Battery Replacement: passo 4, immagine 1 di 1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Sony Xperia M4 Aqua Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Sony Xperia M4 Aqua Battery Replacement: passo 6, immagine 1 di 1
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Sony Xperia M4 Aqua Battery Replacement: passo 7, immagine 1 di 1
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Sony Xperia M4 Aqua Battery Replacement: passo 8, immagine 1 di 1
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
Conclusione
Altre 16 persone hanno completato questa guida.
John Whitt
Membro da: 02/10/16
672 Reputazione
2 Guide realizzate
USF Tampa, Team 4-5, Lacy Spring 2016 Membro di USF Tampa, Team 4-5, Lacy Spring 2016
USFT-LACY-S16S4G5
3 Membri
8 Guide realizzate
11 Commenti
Hi... do you need to add some adhesive to reassemble it? Thanks.
Arief Yuha - Replica
U actually buy another back end cover that has the adhesive....
Chase Bryan -
I found that I could just push it back on with the original glue and it reattached ok.
Dave Humm -
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - Replica
Good video thanks.
I'm currently living in Thailand and they don't fix Sonys here in Krabi so I need to do it myself. Lazada has got the lcd and back cover for me, but they don't have a battery. I have a Sony Xperia aqua m4. Will the z3 battery fit...
Chase Bryan - Replica
The copper tape was ripped when I opened the phone. Can it be repaired?
dee_extrordinaire - Replica
Its an shield for better cooling but its not necessary.So dont worry about it.
indrek2710 -
hello guys, I have a serious problem with sony M4.
the mobile can't sustain any processes , it shuts down and repeatedly restart itself till I forced it to be OFF
I repaired the software and the heat and shut down problems still exist.
Any help to find a solution ?
Ahmed Ibrahim - Replica
From what I read on other forums leads me to believe the battery on my Sony M4 Aqua is the cause of the bootloop. Yes I have tried to use the update/repair software from sony and all it did was reverse the color scheme of the sony logo from black to white.
earthjin2000 - Replica
Mines doing the exact same thing, phone has a two year warranty, I'm sending mine back.
Left a fully charged phone on nightstand last night, woke to phone only having 3% battery
Robert Shadbolt -
Hi my loud speaker is not working properly. It will come on if I put pressure on the screen…any ideas?
Derek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 20,204
