Salta al contenuto principale
Sony Xperia M4 Aqua Back Cover
Cosa ti serve
  1. Sony Xperia M4 Aqua Back Cover, Back Cover: passo 1, immagine 1 di 1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Back Cover: passo 2, immagine 1 di 1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Back Cover: passo 3, immagine 1 di 2 Sony Xperia M4 Aqua Back Cover: passo 3, immagine 2 di 2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Back Cover: passo 4, immagine 1 di 1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
Conclusione
Altre 17 persone hanno completato questa guida.
Brian McKalip
Membro da: 02/10/16
2.100 Reputazione
2 Guide realizzate
USF Tampa, Team 4-5, Lacy Spring 2016 Membro di USF Tampa, Team 4-5, Lacy Spring 2016
USFT-LACY-S16S4G5
3 Membri
8 Guide realizzate
3 Commenti
Thanks. Do you know where to order a new back cover? Mine has shattered
Michael McNicholas - Replica
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - Replica
Reassembling just in reverse order you’ll  get a non-dust and non-waterproof device and not normally fixed rear cover.  You have to apply special Sony Xperia M4 Aqua E2303 Adhesive Sticker, 56BTUL0030A.
Andrey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 8,186
