Salta al contenuto principale
Sony Xperia M2 Logic Board Replacement
Cosa ti serve
Panoramica Video
  1. Sony Xperia M2 Logic Board Replacement, Rear Cover: passo 1, immagine 1 di 3 Sony Xperia M2 Logic Board Replacement, Rear Cover: passo 1, immagine 2 di 3 Sony Xperia M2 Logic Board Replacement, Rear Cover: passo 1, immagine 3 di 3
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Cover is plastic.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
  2. Sony Xperia M2 Logic Board Replacement, Battery: passo 2, immagine 1 di 3 Sony Xperia M2 Logic Board Replacement, Battery: passo 2, immagine 2 di 3 Sony Xperia M2 Logic Board Replacement, Battery: passo 2, immagine 3 di 3
    • Disconnect the Battery Cable.
    • The battery is stuck to the phone fame. Use the white tape to remove it.
    • Li-Polymer Battery, 2230 mAh
    • Part number: LIS1551ERPC
    • Please SUBSCRIBE to my channel ツ
  3. Sony Xperia M2 Logic Board Replacement, Logic Board: passo 3, immagine 1 di 2 Sony Xperia M2 Logic Board Replacement, Logic Board: passo 3, immagine 2 di 2
    • Remove the SIM and the memory cards.
    • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
  4. Sony Xperia M2 Logic Board Replacement: passo 4, immagine 1 di 1
    • Disconnect one by one:
    • Touchscreen flex cable
    • Proximity sensor flex cable
    • Power on, Volume buttons cable
    • SIM & Micro SD flex cable
    • Coaxial antenna cable
  5. Sony Xperia M2 Logic Board Replacement: passo 5, immagine 1 di 2 Sony Xperia M2 Logic Board Replacement: passo 5, immagine 2 di 2
    • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
    • Put one plastic spudger between the Logic board and the Main frame.
  6. Sony Xperia M2 Logic Board Replacement: passo 6, immagine 1 di 3 Sony Xperia M2 Logic Board Replacement: passo 6, immagine 2 di 3 Sony Xperia M2 Logic Board Replacement: passo 6, immagine 3 di 3
    • Step one: move aside less the left side of the board - down.
    • Step two: the left side of the Logic board must go out of the main frame.
    • For this manipulation use only plastic tools.
Conclusione
Altre 16 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
2 Commenti
My mobile charge bin problem how to find that problem , no charged my mobile…
jeeva jeeva - Replica
Removing the motherboard is unnecessarily difficult on this model! Why make it like this? One would figure the screws would do a good enough job of securing it to the frame. I guess having to wiggle it out is just part of the fun, right?
Also, getting parts for this model (and it’s water-resistant twin) sucks. I’m currently in the market for a display+touch assembly and it seems I’ll have to resort to importing from AliExpress.
Luis Alejandro Araúz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 14,406
