Salta al contenuto principale
Sony Xperia L2 LTE Screen Replacement
Cosa ti serve
  1. Sony Xperia L2 LTE Screen Replacement, Battery: passo 1, immagine 1 di 2 Sony Xperia L2 LTE Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Screen Replacement: passo 2, immagine 1 di 3 Sony Xperia L2 LTE Screen Replacement: passo 2, immagine 2 di 3 Sony Xperia L2 LTE Screen Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Screen Replacement: passo 3, immagine 1 di 1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Screen Replacement: passo 4, immagine 1 di 2 Sony Xperia L2 LTE Screen Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Screen Replacement, Motherboard: passo 5, immagine 1 di 1
    • Unclip circuit connectors from phone to motherboard.
  6. Sony Xperia L2 LTE Screen Replacement: passo 6, immagine 1 di 3 Sony Xperia L2 LTE Screen Replacement: passo 6, immagine 2 di 3 Sony Xperia L2 LTE Screen Replacement: passo 6, immagine 3 di 3
    • Use blue plastic opening tool to pry off the motherboard.
  7. Sony Xperia L2 LTE Screen Replacement, Screen: passo 7, immagine 1 di 2 Sony Xperia L2 LTE Screen Replacement, Screen: passo 7, immagine 2 di 2
    • Microwave the iOpener for 30 seconds.
    • Place the iOpener on the phone screen for 90 seconds to loosen the adhesive.
    • Use the suction tool and a pick to remove the screen from the phone.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  8. Sony Xperia L2 LTE Screen Replacement: passo 8, immagine 1 di 1
    • Unhook the screen sensor from the phone to detach the screen from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,146
