Salta al contenuto principale
Sony Xperia L2 LTE Charging Port Replacement
Cosa ti serve
  1. Sony Xperia L2 LTE Charging Port Replacement, Battery: passo 1, immagine 1 di 2 Sony Xperia L2 LTE Charging Port Replacement, Battery: passo 1, immagine 2 di 2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Charging Port Replacement: passo 2, immagine 1 di 3 Sony Xperia L2 LTE Charging Port Replacement: passo 2, immagine 2 di 3 Sony Xperia L2 LTE Charging Port Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Charging Port Replacement: passo 3, immagine 1 di 1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Charging Port Replacement: passo 4, immagine 1 di 2 Sony Xperia L2 LTE Charging Port Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Charging Port Replacement, Charging Port: passo 5, immagine 1 di 2 Sony Xperia L2 LTE Charging Port Replacement, Charging Port: passo 5, immagine 2 di 2
    • Use a plastic opening tool to lift the charging port circuit board.
  6. Sony Xperia L2 LTE Charging Port Replacement: passo 6, immagine 1 di 1
    • Unhook the antenna from circuit board using a plastic opening tool and remove the charging port circuit board from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 628
