Introduzione
To complete this guide you will need to disassemble your device and use tweezers to extract the SIM card reader.
The battery should be removed before working on the phone internals.
Cosa ti serve
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
Using the tweezers lift the plate out of the clamps, from left to right.
Then remove the whole plate off the phone.
Altre 5 persone hanno completato questa guida.
