Salta al contenuto principale
Sony XPERIA Tablet Z Volume Button Replacement
Cosa ti serve
  1. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: passo 1, immagine 1 di 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: passo 1, immagine 2 di 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
    • Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
  2. Sony XPERIA Tablet Z Volume Button Replacement, Locate the Volume module: passo 2, immagine 1 di 1
    • Locate the volume module.
    • Remove both screws using the Philips screwdriver.
  3. Sony XPERIA Tablet Z Volume Button Replacement, Lift out of Place: passo 3, immagine 1 di 1
    • Once both screws are removed grab the tweezers.
    • Then lift up on the module.
  4. Sony XPERIA Tablet Z Volume Button Replacement, Removing the Electrical tape: passo 4, immagine 1 di 1
    • Find the electrical tape connecting the module to the motherboard
    • Carefully pull out the electrical tape horizontally and remove the volume module from the device.
Conclusione
Martin Luna
Membro da: 09/24/14
1.873 Reputazione
5 Guide realizzate
USF Tampa, Team 15-6, Remmell Fall 2014 Membro di USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,528
