Salta al contenuto principale
Sony XPERIA Tablet Z Screen Replacement
Cosa ti serve
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, immagine 1 di 3 Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, immagine 2 di 3 Sony XPERIA Tablet Z Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: passo 2, immagine 1 di 3 Sony XPERIA Tablet Z Screen Replacement: passo 2, immagine 2 di 3 Sony XPERIA Tablet Z Screen Replacement: passo 2, immagine 3 di 3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: passo 3, immagine 1 di 1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: passo 4, immagine 1 di 1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: passo 5, immagine 1 di 1
    • Clean adhesive from perimeter of frame to prepare for new screen.
Conclusione
Altre 8 persone hanno completato questa guida.
IUPUI, Team S5-G1, Harley Summer 2017 Membro di IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Membri
3 Guide realizzate
5 Commenti
اريدشراءاريدشراءشاشه جديده
kore ares - Replica
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Replica
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Replica
Wooo its self explanatory.Good work
Duncan Mwaniki - Replica
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 6,862
