Salta al contenuto principale
Sony XPERIA Tablet Z SIM and SD card reader Replacement
Cosa ti serve
  1. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: passo 1, immagine 1 di 3 Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: passo 1, immagine 2 di 3 Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: passo 1, immagine 3 di 3
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive
    • Remove cover
  2. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, locating the SD card reader: passo 2, immagine 1 di 1
    • Locate the SD card reader in the bottom left hand corner
    • Remove all screws connecting the metal plate to the device.
  3. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Lift up: passo 3, immagine 1 di 1
    • After all the screws have been removed lift the circuit board up to wiggle free.
  4. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Disconnecting electrical tape.: passo 4, immagine 1 di 1
    • After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
    • Once placed there lift up and disconnect the SD card reader from the device.
Conclusione
Martin Luna
Membro da: 09/24/14
1.858 Reputazione
5 Guide realizzate
USF Tampa, Team 15-6, Remmell Fall 2014 Membro di USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Membri
7 Guide realizzate
Un commento
How long did it take to complete???
Steve Donnelly - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,173
