Introduzione
By replacing your Volume Knob, you will certainly turn up/down the volume of your music much smoother. Since this is the most usable button of the device, it will defiantly have a lower performance on the long run.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
  1. Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards. Remove the ten 3.5mm Phillips #0 screws from the back plate. Remove the ten 3.5mm Phillips #0 screws from the back plate.
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Use a plastic opening tool to remove the back plate. Don't remove completely as there will still be cables connected.
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Disconnect the USB cable from the display board.
    • Disconnect the USB cable from the display board.
  4. Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel. Pull the USB cable off of the back plate. Pull the USB cable off of the back plate.
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  7. Disconnect the display power cable from the motherboard. Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  8. Unscrew the four 3.5mm Phillips #0 screws from the motherboard. Use a spudger to gently lift the motherboard up and out of the radio. Use a spudger to gently lift the motherboard up and out of the radio.
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  9. Remove the four 3.5mm Phillips #0 screws from the sides of the display.
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  10. Remove two 3.5mm Phillips #0 screws from the back of the head unit. Remove two 3.5mm Phillips #0 screws from the back of the head unit.
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  11. Remove the four 3.5mm Phillips #0 screws from the display board. Remove the black tape using a precise tweezer. Remove the 3.5mm Phillips #0 screw from underneath the tape.
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  12. Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  13. Remove the single 2mm Phillips #0 screw from the motherboard.
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  14. Use a plastic opening tool to remove the display board from the radio.
    • Use a plastic opening tool to remove the display board from the radio.
  15. Remove the silver knob cover by pulling upwards on it. Remove the plastic face plate. Pull off the black knob.
    • Remove the silver knob cover by pulling upwards on it.
    • Remove the plastic face plate.
    • Pull off the black knob.
Conclusione
Abdulaziz Redha
Membro da: 22/02/2018
642 Reputazione
5 Guide realizzate
USF Tampa, Team S1-G5, Cagle Spring 2018 Membro di USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 75
Tutti i Tempi: 672
