Salta al contenuto principale
Sony XAV-AX100 USB Cable Replacement
Cosa ti serve
  1. Sony XAV-AX100 USB Cable Replacement, USB Cable: passo 1, immagine 1 di 3 Sony XAV-AX100 USB Cable Replacement, USB Cable: passo 1, immagine 2 di 3 Sony XAV-AX100 USB Cable Replacement, USB Cable: passo 1, immagine 3 di 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 USB Cable Replacement: passo 2, immagine 1 di 2 Sony XAV-AX100 USB Cable Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 USB Cable Replacement: passo 3, immagine 1 di 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 USB Cable Replacement: passo 4, immagine 1 di 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 USB Cable Replacement: passo 5, immagine 1 di 3 Sony XAV-AX100 USB Cable Replacement: passo 5, immagine 2 di 3 Sony XAV-AX100 USB Cable Replacement: passo 5, immagine 3 di 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
Conclusione
USF Tampa, Team S1-G5, Cagle Spring 2018 Membro di USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Membri
5 Guide realizzate
3 Commenti
Where i can get replacement lead?
mudylla - Replica
where can i get a replacement lead for this please
Andy 777 - Replica
im in the UK
Andy 777 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 52
Tutti i Tempi: 4,074
