Introduzione
This repair guide will demonstrate how to properly replace your Main Motherboard on your device. By doing so, you can crucially extend the lifespan of your device. In addition, you will also experience much faster response time from your device.
Cosa ti serve
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
Pull the USB cable off of the back plate.
Our radio is not interfacing with my phone it says USB connection problem before I tear it all apart what else could it be thank you
Disconnect the display power cable from the motherboard.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
