Salta al contenuto principale
Sony XAV-AX100 Display Replacement
Cosa ti serve
  1. Sony XAV-AX100 Display Replacement, USB Cable: passo 1, immagine 1 di 3 Sony XAV-AX100 Display Replacement, USB Cable: passo 1, immagine 2 di 3 Sony XAV-AX100 Display Replacement, USB Cable: passo 1, immagine 3 di 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Display Replacement: passo 2, immagine 1 di 2 Sony XAV-AX100 Display Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Display Replacement: passo 3, immagine 1 di 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Display Replacement: passo 4, immagine 1 di 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Display Replacement: passo 5, immagine 1 di 3 Sony XAV-AX100 Display Replacement: passo 5, immagine 2 di 3 Sony XAV-AX100 Display Replacement: passo 5, immagine 3 di 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Display Replacement, Motherboard: passo 6, immagine 1 di 2 Sony XAV-AX100 Display Replacement, Motherboard: passo 6, immagine 2 di 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Display Replacement: passo 7, immagine 1 di 3 Sony XAV-AX100 Display Replacement: passo 7, immagine 2 di 3 Sony XAV-AX100 Display Replacement: passo 7, immagine 3 di 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Display Replacement, Display: passo 8, immagine 1 di 1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Display Replacement: passo 9, immagine 1 di 2 Sony XAV-AX100 Display Replacement: passo 9, immagine 2 di 2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team S1-G5, Cagle Spring 2018 Membro di USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Membri
5 Guide realizzate
3 Commenti
Where do you get a replacement screen?
I need one for a xav 3005 db
Morten Hjorth-Johansen - Replica
Thank you very much for this great write up.
However after having performed it, if all you are doing is replacing the screen, then steps 1, 4, 5 and 7 are actually completely unnecessary . There is no need to remove the back panel or the motherboard.
but thank you nonetheless for having shown the way.
Robert Edwards - Replica
I need to get a replacement screen for a Sony xav 1500 any idea of a cheap place?
Abelardo M. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 59
Tutti i Tempi: 4,791
