Salta al contenuto principale
Sony Walkman WM-AF48 Outer Cover Replacement
Cosa ti serve
  1. Sony Walkman WM-AF48 Outer Cover Replacement, Getting started: passo 1, immagine 1 di 1
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Outer Cover Replacement, Remove the outer cover: passo 2, immagine 1 di 3 Sony Walkman WM-AF48 Outer Cover Replacement, Remove the outer cover: passo 2, immagine 2 di 3 Sony Walkman WM-AF48 Outer Cover Replacement, Remove the outer cover: passo 2, immagine 3 di 3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
There are four tabs on the WM-AF48 Model inside the door and around the body that are made to release the back cover.
Ethan Jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,765
