Salta al contenuto principale
Sony Walkman NWZ-E438 USB Port Replacement
Cosa ti serve
  1. Sony Walkman NWZ-E438 USB Port Replacement, Disassembling Sony Walkman NWZ-E438: passo 1, immagine 1 di 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 USB Port Replacement: passo 2, immagine 1 di 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: passo 3, immagine 1 di 3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: passo 3, immagine 2 di 3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: passo 3, immagine 3 di 3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 USB Port Replacement: passo 4, immagine 1 di 2 Sony Walkman NWZ-E438 USB Port Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 USB Port Replacement: passo 5, immagine 1 di 1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 USB Port Replacement: passo 6, immagine 1 di 1
    • Carefully remove the circuit board from the device.
  7. Sony Walkman NWZ-E438 USB Port Replacement, USB Port: passo 7, immagine 1 di 1
    Compra
    • Using fine point tweezers, push them between the chip and USB port.
  8. Sony Walkman NWZ-E438 USB Port Replacement: passo 8, immagine 1 di 1
    • Slowly pry the USB port off of the chip.
    • You will need to solder the new USB onto the circuit board.
  9. Sony Walkman NWZ-E438 USB Port Replacement: passo 9, immagine 1 di 1
    • Remove USB port.
Conclusione
Un commento
Wher buy new port????pavel87cz@gmail.com
Pavel Drobny - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 596
