Salta al contenuto principale
Sony Walkman NWZ-E438 Screen Replacement
Cosa ti serve
  1. Sony Walkman NWZ-E438 Screen  Replacement, Disassembling Sony Walkman NWZ-E438: passo 1, immagine 1 di 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Screen  Replacement: passo 2, immagine 1 di 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Screen  Replacement, Screen: passo 3, immagine 1 di 1
    • Pull up the 2 copper strips connecting the outside of the device to the inside of the device.
  4. Sony Walkman NWZ-E438 Screen  Replacement: passo 4, immagine 1 di 1
    • Using the small, plastic prying tool wedge it between the bottom of the frame and the outer frame.
    • Slowly circle the device, popping the outside of the frame off.
  5. Sony Walkman NWZ-E438 Screen  Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • To remove the screen, use the fine point tweezers and lift up on the metal piece at the bottom of the frame.
  6. Sony Walkman NWZ-E438 Screen  Replacement: passo 6, immagine 1 di 1
    • To remove screen from metal backing, use fine point tweezers to go in between the screen and metal backing and slowly pull them apart.
  7. Sony Walkman NWZ-E438 Screen  Replacement: passo 7, immagine 1 di 1
    • The screen will be removed.
Conclusione
Un commento
wher buy display
Pavel Drobny - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 687
