Salta al contenuto principale
Sony Walkman NWZ-E438 Headphone Jack Replacement
Cosa ti serve
  1. Sony Walkman NWZ-E438 Headphone Jack Replacement, Disassembling Sony Walkman NWZ-E438: passo 1, immagine 1 di 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Headphone Jack Replacement, Headphone Jack: passo 3, immagine 1 di 1
    • Unscrew the 1 screws around the headphone jack using Phillips PH000 screwdriver.
  4. Sony Walkman NWZ-E438 Headphone Jack Replacement: passo 4, immagine 1 di 2 Sony Walkman NWZ-E438 Headphone Jack Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the fine pointed tweezers, unplug the cords connecting the headphone jack to the chip.
  5. Sony Walkman NWZ-E438 Headphone Jack Replacement: passo 5, immagine 1 di 3 Sony Walkman NWZ-E438 Headphone Jack Replacement: passo 5, immagine 2 di 3 Sony Walkman NWZ-E438 Headphone Jack Replacement: passo 5, immagine 3 di 3
    • Remove the headphone jack.
Conclusione
2 Commenti
hi there, i have mine apart but where do i get a spare one to refit, please help
lee manock - Replica
Can you make a tutorial on how to replace the headphone jack on the sony nwz-s774?
petermedz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 827
