Salta al contenuto principale
Sony Walkman NWZ-E438 Device Circuit Board Replacement
Cosa ti serve
  1. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Disassembling Sony Walkman NWZ-E438: passo 1, immagine 1 di 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Device Circuit Board Replacement: passo 2, immagine 1 di 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: passo 3, immagine 1 di 3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: passo 3, immagine 2 di 3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: passo 3, immagine 3 di 3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 Device Circuit Board Replacement: passo 4, immagine 1 di 2 Sony Walkman NWZ-E438 Device Circuit Board Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 Device Circuit Board Replacement: passo 5, immagine 1 di 1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 Device Circuit Board Replacement: passo 6, immagine 1 di 1
    • Carefully remove the circuit board from the device.
Conclusione
For reassembling your device, follow the instructions in reverse.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 531
