Salta al contenuto principale
Sony Walkman NWZ-E438 Battery Replacement
Cosa ti serve
  1. Sony Walkman NWZ-E438 Battery Replacement, Disassembling Sony Walkman NWZ-E438: passo 1, immagine 1 di 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Battery Replacement: passo 2, immagine 1 di 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Peel back the black tape from the device to the battery from the side of the device.
  4. Sony Walkman NWZ-E438 Battery Replacement: passo 4, immagine 1 di 1
    • Using a small, plastic prying tool slowly lift the battery around all edges.
    • Careful of wires connecting the battery to the device.
  5. Sony Walkman NWZ-E438 Battery Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the yellow film covering the circuit board with pointed precision tweezers.
  6. Sony Walkman NWZ-E438 Battery Replacement: passo 6, immagine 1 di 2 Sony Walkman NWZ-E438 Battery Replacement: passo 6, immagine 2 di 2
    • Using tweezers, unplug the gold band connecting the device and circuit board.
  7. Sony Walkman NWZ-E438 Battery Replacement: passo 7, immagine 1 di 2 Sony Walkman NWZ-E438 Battery Replacement: passo 7, immagine 2 di 2
    • Using pointed precision tweezers, unplug the wires connecting the battery and chip from the chip.
  8. Sony Walkman NWZ-E438 Battery Replacement: passo 8, immagine 1 di 1
    • Remove battery.
Conclusione
Un commento
Do you have a link to purchase a replacement battery? Thanks!
jacob goff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 64
Tutti i Tempi: 6,541
